Resolved 2G 6 bolt block 7 bolt head..
JCH1979KY
Nov 11, 2009
CHATTAROY, West Virginia
ok just found out my car has a 6 bolt block... but from what i can tell it has a 7 bolt head...
my question is does this give u more power..
or would i be better off going back to a 6 bolt head
the car is a 98 awd
i did a search but couldnt find the benifits of running that head with that block
Honestly it's nothing you are going to notice...but rule of thumb is:
7-Bolt head better down low, 6-Bolt head fly up high.
Basically I am saying the 6-Bolt flows better at higher RPMs.
It depends on what you have . . . My 2G has a 6 bolt stroker(2.3) with the stock/mildly ported 2G head. The slightly smaller ports on the 2G head increase intake charge velocity at low-to-midrange rpm`s, which compliments the stroker platform very well. If you plan to rev to the stratosphere, go with a 1G head . . . :talon:
Like talontrax said it depends on your setup, its been proven though the 2g head can out flow the 1g head. Most people go with 1g head which is very effective but a 2g head with intake openings matched to 1g large ports will increase intake velocity through out low to high RPMS
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
