tweek814
- 86
- Nov 20, 2009
Charleston,
South Carolina
Hey guys, im going to look at a car this weekend. Its a 97 GSX auto. 153k. He only wants $1800 for it.
The guy says that the only problem with it is it has a bad turbo. I have never owned a boosted car but am slightly familiar with the concept, thats about it. So what im asking of you guys is, How do i check to see for sure that the turbo is bad? Besides smoking, no boost pressure, and checking for left/right play in the turbine? And could a bad turbo cause any other problems in the motor?
If the turbo does in fact need replaced, should i replace it with a stock turbo, or are upgraded turbos available that bolt right up with the stock manifolds/lines?
Also, anything else i should look for in a 4G63T, or 2g in general?
Oh yeah, the car is a good hour and a half away, would i be ok driving it home if it is in fact a bad turbo.
thanks in advance.
thanks in advance.
