jmkoons
- Feb 16, 2006
Santa Barbara,
California
DSMers,
I've looked thoroughly and not come across this type of misalignment issue in any driveline related thread. All other posts address either spacing problems regarding the A/C bracket, using an incorrect bracket for model year, or lateral spacing issues from either - a) intermediate shaft and halfshaft not fully seating together, b) halfshaft having issues seating into wheel, c) intermediate shaft having issues seating into gearbox.
This problem relates to none of the above. Car is at a garage after having the transmission rebuilt at Jack's. Quaife upgrade was done long ago, but something went haywire with the differential around August this year, and I obtained a warranty repair from the original seller. Jack's dropped the Quaife back in, gave me all new gears and a few upgrades, and shipped it back to the garage doing the R&R for the transmission.
The garage tells me that the intermediate shaft bolt holes are off by about 1/4 inch, with the bracket sitting slightly low. They won't continue without my permission to attempt forcing it in, but maybe that's a bad idea if it will strain the brand new rebuild I've waited 4 months to have finished (mainly due to warranty issues with the Quaife). The bracket apparantly came out fine, and they are at a loss as to why it won't line up vertically going back in, so they kicked the problem back to me and stopped work.
Reply from Jack's was that there is no reason why the shaft should not seat properly going back in. The equal-length conversion on my FWD car was done long ago, and no one has ever remarked that I had the wrong parts or that fitting was any problem going in and out for either shaft before. Thanks in advance for your replies!
) that it looks like one of my diff bearings was from a non-turbo, while the other was for a turbo model. The races fit snugly, but each bearing actually has a different taper angle to it. In reality, this shouldn't matter, but it looks like the non-turbo bearing may stick out a little farther than the turbo, and could have been misaligned for that fact. I have ordered a new bearing, and will post results.
I'm probably going to go the slotting the bracket route and see if that fixes it and then search for a new intermediate shaft. I can get it bolted in, but it doesn't spin smooth and I can tell there is binding going on.
