6boltlaser
- Nov 17, 2009
Colo springs,
Colorado
I just got done putting a 92 fwd transmission into my 90 laser I have been searching for awhile about all the steps for this trans swap but Im still having problems...I dont have 1st or 2nd gear,Im using the 90 shifter with 92 shifter cables along with the 92 shifter bracket right now..I read on v-faq that I need to use the 90 shifter cable bracket with 91-94 shift cables but when I do that I cant get the car into any gear...I also tried using my 90 shifter cables with the 92 bracket and got 1st thru 4th gear no reverse or 5th gear so I tried that along with swappin the vertical arm on the trans for my 90s arm still no luck.......Is there something im missing..I also tried using the 92 shifter with no luck
Can someone explain to me the proper steps when putting a 91-94 trans in a 90 cause everything I try doesnt work and leaves me with 2 gears missing
