Attemptimg a full timing belt, w/p, oil pump & case etc - I have a few Questions HELP
turbotemper
203
Jan 23, 2009
Fresno, California
Well i was quoted $400 labor + parts by a reputable shop here, who did my timing & seals etc back at 90k miles.
Well I want to attempt this myself & i am going to be doing it on a limited budget.
I have a few questions for some of you who have successfully been able to complete the job.
My car is a 95 GST w/ 147K miles and recently it broke the timing belt or the tensioner let go. I will know once its on jack stands & i lower the motor & remove the case. As of now its been 2 weeks w/ no leaks from the timing cover area so i dont think i spun a bearing in the b/s. It was making a funny sound for a while before this but i couldnt track it down. I checked my hb/cp but it was in great condition. I took the upper timing cover off and it looked tight and again in the morning and all was the same, so i drove it easy because thats the only driving car i own LOL(projects) And months and k's of miles later it just went on me. I knew something was coming... So now she sits and i want to get it road worthy again.
I am going with mits tensioner, balancer tensioner pulley, timing belt tensioner pulley, timing belt idler pulley. I need a new w/p as well as oil pump & maybe oil case im sure.
I was in Extreme PSI's site looking at the timing components section and saw this:EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Front Case Castle Plug: Mitsubishi Eclipse 90-99
Its a front case castle nut and o ring. Is this a required piece while im in there swapping in new stuff? Where does it go anyhow? I dont recall seeing this in any of the threads ive read.
As for the Balance Shaft Im still undecided as to get the BSE kit or replace the B/S bearing and belt and keep it.
I was planning on dropping the oil pan and checking for crank play at this time as well.
Should i replace the bearings while im in there? Why would i or should i change them? Same with the thrust bearings? IDK what to do & i want to keep this thing running for a long time. Help Guys!?!
I can tell this is gonna be a long thread with some great information for everyone interested in doing it themselves :hellyeah:
yea do that before you proceed there is a good chance you will need new valves which could change your decision.
Well looks like the mighty mitsu will be down for repairs for the winter if not longer:cry: I have to finish my 01 turbo mustang gt. Has a built/stroked 4.6L to 5.0L w/ forged internals, cnc'd stg 2 h/c's, Trick Flow Intake Manifold, soon to have an on3performance 70mm turbo kit w/ FMIC and lots of supporting goodies. That was my project car & now it will be my DD after i get the heads rebuilt on that. Money money money. Its cheaper to finish the stang at this point and then i can slowly fully rebuild the mitsu. I'll be content w/ a low 12 second 2.0L pump gas car, which isnt too hard these days all it takes is money LOL.
Thank you to all the aftermarket DSM vendors and all the support you can get on the forums:hellyeah:
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
