Help My Car Doest Acelerate ###ZZ Video here
The4g63tKid
Nov 13, 2009
San Juan, Pennsylvania
Hi I Have A 1g Talon Tsi Im Having A Big Problem Here And I Need Help You Acelerate The Car And It Wont Accelerate And And Sometimes Back Fires Heres A Video Not Good Quality But Listen When I Acelerate The Car My Car Is Completely Stock Only Walbro 255 Fuel Pump And bore 0.40 it Was Running Fine It Hapenned After I Took Off Hard On It in de vid I Was Acelerating The Car And it Wont Acelerate And When I Let Go The Accelerator Cable The Engine Shut Off Or Turned Off How ever You Say it IM From Puerto Rico And Don't Know Too Much English Hope You Can Understand Me
YouTube - Video0002
check for boost leaks! Check all your piping make sure you didn't blow something apart.
You might also be flooding your car with stock mods and a 255. It will run but you should try putting in a 190lph.
Another thing you could check is spark plugs.
Good Luck.
Oh yea , It sounds like a big boost leak , check for blown coupler. It sounds exactly the same as mine when I popped a coupler. I bet you are running really rich.
im running stock boost no hose is broken or boost leak nothing im gonna check timing when you first start the engine it revs fine but just one time then it starts doing that thing i have cheked hoses vacums car is not running rich even if i put it to run rich will do the same thing thanx ill update later
