Whats Wrong with my car? VIDEO
Posted by DSMnOOb00, Jun 18, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support STM Tuned
  1. DSMnOOb00
    DSMnOOb00 Proven Member
    DSM Profiles:
    Apr 29, 2006
    758
    FRESNO, California
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/XoPkL-aohEk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/XoPkL-aohEk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
    first it has a tough time getting started and gives out a LOUD squeek before it fires up, and if i rev too high it dies...
    help! :confused:
    #1
  2. Dsm4lyfe12
    Dsm4lyfe12 Proven Member
    DSM Profiles:
    Jun 8, 2010
    341
    Minooka, Illinois
    Sounds like a belt to me. The tensoner rod in eagles and eclipses is really bad. My talon does it with the alt belt. I'd do a boost leak test first. have you checked the spark plugs? The tick sounds terrible, could be a messed up head, or crank walk. Question is 6 bolt or 7 bolt? Why wasnt in running, more info please!
    Thanks!
    #2
  3. DSMnOOb00
    DSM Profiles:
    Apr 29, 2006
    758
    FRESNO, California
    its a 7bolt, it wasnt making the sound a few weeks ago.. I havent drivin the car in a LONG time, I just start it up everyonce in a while to keep everything warm.
    that squeek just started...
    #3
  4. Dsm4lyfe12
    DSM Profiles:
    Jun 8, 2010
    341
    Minooka, Illinois
    Does it have soft pipes? Do you have any gauges?(moniter these), i have so many in my car there isnt any room for error. soft pipes like to dry rot. If i'd have someone start it and listen on the crank side,and for the belts. Do a boost leak test and tell me how it goes. Could be your timing belt slipping also Check that as soon as possible! avoid reving to high just incase it is.
    #4
  5. DSMDavid85
    DSMDavid85 Probationary Member
    DSM Profiles:
    Dec 11, 2009
    6
    Homestead, Florida
    noises are a bastard sometimes,i only hear the noise when it starts. it could be a belt or the starter. get some belt dressing or just wet the belts a little then start it see if the noise changes ,if it does then there you go. have some one help you listen on startup and also check to see if there are cracks in the belts.(check the starter to). that tick souns like a single tick like a bad lifter!!!!!.
    as for the car stalling when it comes back to idle speeds, check for air leaks!!!/vac leaks. turn the ac on and see if it still does it!!!
    #5
  6. DSMnOOb00
    DSM Profiles:
    Apr 29, 2006
    758
    FRESNO, California
    Good advice guys! I'll check all the soft pipes and look for leaks. I just bought a can of belt dressing to see if the squeek goes
    #6
  7. under50k226
    under50k226 Proven Member
    DSM Profiles:
    Dec 2, 2007
    52
    Colorado Spring, Colorado
    help! :confused:[/QUOTE]
    Sounds to me like you should change your oil and service all the belts, tensioners and rollers on the side of the engine. The car just sounds like its had its ass kicked. I don't know what that tick is because I can't really hear the depth of it from the mic on the camera. From here it sounds like valve tick but as that dude was so quick to jump to; it could be worse. Don't go toss yourself into a panic over anything, just service your car properly, and don't run idiotic boost for your set up and you should be okay, well maybe...
    :talon:
    #7
  8. Dsm4lyfe12
    DSM Profiles:
    Jun 8, 2010
    341
    Minooka, Illinois
    Actually, this dude was trying to help i was saying the tick from what i can hear sounds bad. and might want to be checked. Usually every car has a lifter tick,(aluminum head) But typically since any 1g or 2g has a cast iron head there isnt a big problem with lifters or ticks. I was asuming that the car hasnt been started in a while and it could just be oil pressure:D i forgot to post that. Check the timing and the crank for any "give" if it moves back in forth.
    #8
  9. awdmonster1904
    awdmonster1904 Supporting Member
    DSM Profiles:
    Aug 23, 2007
    327
    20
    Ontario, California
    ticking can also be exhaust leak
    #9
  10. DSMnOOb00
    DSM Profiles:
    Apr 29, 2006
    758
    FRESNO, California
    I just changed the oil in the car and it just came back from the shop for turbo/o2 housing port n polish
    car hasnt been on the road for about 2years... ever since I had the engine rebuilt it has giveing me nothing but problems ( BUT GOD I LOVE HER! )
    I havent had time to try anything yet but any and all advice is much appreciated
    I did find a hole in my exhaust muffler, would that hurt anything that far down in the exhaust?
    #10
  11. DSMnOOb00
    DSM Profiles:
    Apr 29, 2006
    758
    FRESNO, California
    Any comments on whether or not the having a hole in the muffler would make the engine click?
    Also I have a question about fouled up spark plugs, I know that having a really bad boost leak might cause fouled up sparks but what else would?
    #11
  12. Cyboula
    Cyboula Probationary Member
    Apr 13, 2010
    9
    Bauru, South_America
    dude, check your spark wires
    IF ITS IN THE CORRECT POSISTION TOO.
    I hope im right :D
    Good luck !
    #12
  13. gieri002
    gieri002 Proven Member
    Feb 25, 2008
    729
    Lake Minnetonka, Minnesota
    You have a serpentine belt that is a bit loose or worn that is where the squeak comes from, there are only two I'm sure you can find it. Don't be worried about the tick, its called lifter tick to get this to go away you need to buy the revised 3g lifters, they are about $100 (search the forums for this.). When you rev high the idle doesn't seem to catch, this is because of a boost leak, I would recommend just tightening the clamps on all of your intercooler piping and see if it helps otherwise just make a home depot boost leak tester (search the forums for this also). These are all problems that are very easy to fix all you need to do is search the things I just pointed out and your car will be running perfect in no time.
    #13
  14. staztrx250
    staztrx250 Proven Member
    DSM Profiles:
    Mar 29, 2010
    169
    Green Bay, Wisconsin
    Soulds like the good old crank walk to me. The loud squeak is probably from the bad rod bearing. once it gets some oil its fine well except for the fact that it knocks. I would change oil maybe try a heavier wait oil see if the knock goes away but to me it sounds like more tan just lifter tick. It sounds like rod knock from a bad rod bearing.
    #14
  15. BLINKY619
    BLINKY619 Proven Member
    DSM Profiles:
    Feb 26, 2010
    1,028
    3
    SAN DIEGO, California
    is that rod knock? or exhaust leak..!!!
    #15
  16. DSM1G90
    DSM1G90 Supporting Member
    DSM Profiles:
    Apr 6, 2008
    4,826
    53
    Nampa, Idaho
    (psst! .. Motor's same as yours - one belt to run the alt and WP and the small one to run the PS. No, 'serps' here.)
    Squeaking is coming from the starter. Starters don't like being fired up all the time and the bronze sleeve bearing on the spindle expand due to getting hot and the shaft gets a bit of play.
    That ticking is real sad like that lifter is shot.
    #16
  17. 974g63t
    974g63t Proven Member
    DSM Profiles:
    Mar 17, 2009
    41
    Liberal, Kansas
    My car has a stuck lifter and sounds just like it
    #17
  18. gieri002
    Feb 25, 2008
    729
    Im telling you buddy go through exactly what I told you and your car will be perfect.
    #18
  19. Shadow21
    Shadow21 Proven Member
    Oct 21, 2007
    155
    Charleston, South_Carolina
    interesting. Your oil gauge doesnt move when you rev the engine. Is your oil pump going bad?
    #19
  20. dtdeg
    dtdeg Proven Member
    DSM Profiles:
    Oct 17, 2007
    43
    groningen, Europe
    your engine sounds realy bad. Check the oil level etc. You'r oil presure doesnt rise a bit when revving,i think the head isn't getting enough oil and thats way you'r lifters are making noise My advise dont run that engine before you know whats wrong.
    #20
  21. NV_GSX
    NV_GSX Probationary Member
    Jun 23, 2010
    9
    Salinas?Reno, Nevada
    sounds like your belt also i would upgrade to 3g lifters... if thats whats causing that ticking noise... unless its the exhaust manifols having a leak
    #21
  22. thomcasey
    thomcasey Proven Member
    Dec 16, 2009
    766
    19
    Indianapolis, Indiana
    +1, especially check the recirc tubing for the BOV. IF it is leaking there, you will have the same issue. Mine did that when I was running a non-recirc BOV (it came with the car that way, I found a 1G BOV at a pull-a-part for 2 bucks to fix the issue).
    Agree on the lifters and belt issue too. If this has been sitting for a while, the belts are an easy $20 fix for the squeak.
    #22
  23. Dsm4lyfe12
    DSM Profiles:
    Jun 8, 2010
    341
    Minooka, Illinois
    There are no sepentines in these motors. Its a bronze starter sleve bushing, or another worn belt that makes the noise. As i brought up the problem of the "ticking" it sounds like the good rod knock on a 7 bolt, as i said before check the crank for "play", oil levels, filters ect. Worse comes to worse if you dont know what your doing(not in a rude way) just have a trusted mechanic look it at so they dont get you putting parts in your car that you dont need. Also, to those who think its a lifter tick, ill send you a video of a lifter and a rod knock or a bearing . This most definitely sounds a little bit louder then a lifter or even a exaust leak wouldnt make that loud of a clicking that far in the back..
    Dsmnoob- The exaust leak in your car could be making your car dieing. My old car has a hole in the headers and would die if rev'd to high, on a turbo car that runs off of exaust fumes might be more dependant on a closed exaust.
    1. Boost leak check.
    50-100-$http://www.dsmtuners.com/forums/art...-boost-leak-test-how-boostpro-net-tester.html
    5-10 at home depo-http://www.vfaq.com/mods/ICtester.html
    2. Check all belts for cracks, tears, or the looseness of the belts(except the timing which is dependant on where the motor sits)
    http://home.comcast.net/~tnunley/plenum_gasket/cracked belt.jpg
    3.Replace the muffler(Get done for cheap at a shop)
    4.Maintenance (Oil filter, fuel filter, oil, belts if needed, plugs, and wires)
    5.Get your motor, compression tested(for free) and as i said before a good mechanic to check for crank walk and the ticking noise so people on here can get some peice of mind.
    Hope that helps! Best of luck
    Dan
    #23
  24. tenn-gsx
    tenn-gsx Proven Member
    DSM Profiles:
    Apr 25, 2006
    855
    12
    Fort Worth, Texas
    Your not going to hear crankwalk. If you hear anything while you have crank walk then its either rods knocking or the main bearings spinning. Not crankwalk. Now you could have crankwalk at the same time as a spun main or rod knock. They however are not the same thing. People need to stop throwing crankwalk out there as the first thing thats wrong. Very few of the issues diagnosed as "crankwalk" on this forum actually are.
    #24
  25. Dsm4lyfe12
    DSM Profiles:
    Jun 8, 2010
    341
    Minooka, Illinois
    Not saying the problem is crank walk, just to check for it, common problem bud :D always good to check on them seven bolts.
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
