Burntz
- 97
- 1
- Oct 21, 2009
Lincoln,
Nebraska
So I finally got around to pulling codes tonight, got these:
Map/Baro Sensor
IAT Sensor
Cam Sensor
(96 talon, completely 100% stock 7 bolt / car)
I went and grabbed a friends MAF, the car actually ran, but terrible, wouldn't rev past 1300 rpms, and was running super rich. We did get it to warm up though.
Try adjusting tps a bit, car reverts back to running for 3 seconds and dying, like it almost always does, even with my MAF.
Tested the fuel pump, its getting correct voltage consistently.
Grabbing a friends ECU tomorrow to stick in there, then possible the same guys DSMLink v3 to log and monitor wtf is goin on.
Thinking replace the cam sensor? I don't see any way to test it, besides making sure the pigtail is getting voltage, without pulling the timing belt and exhaust cam gear.
Map/Baro Sensor
IAT Sensor
Cam Sensor
