Compression Questions
ross932c
Oct 16, 2009
Lodon, ON, Canada
Hello there again. I just ran a compression test on my engine. It has 110-150 across the board. I realize it is low but was told it is the Camshafts. I have Compcam camshafts and AEM camgears. I have the gears set both at 0. I was wondering if the compression is normal to be that low because of the cams? The car runs good, but a rough idle ( I assume the cams again) Thanks again
150 would be ok, but you are looking at an almost 25% difference in the lowest/highest cylinder. Usually 10% is the max. As stated do a leak down test. Try adding a cap full of oil and redo the compression test. Remember to max sure the motor is warmed up, all plugs are out and throttle is held open during cranking.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
