spammy123
- 70
- Jan 26, 2008
stow,
Ohio
so my clutch went on my 92 laser awd. this led to me deciding to pull the engine while i was pulling the trans and basically clean some stuff up make sure everything is tip top. not really planning on upgrading or replacing anything unless necessary. question is, while the engine is out, what should i get done as far as machine work or anything of the sort. i figure while its out i might as well get some work done so i don't have to worry about it later. im getting the block hot bathed, as well as the head at least cleaned and obviously replacing all necessary gaskets. i was thinking valve job as well. any help is much appreciated
