Crane #12 or #14 Cam?
*97GS_Eclipse*
Which would be a better cam choice? The Crane 12 or 14 cam? Its going into a 97 Eclipse GS. Other mods along with it would be catback, intake, 12.5 comp pistions, header, headwork, etc. Any thoughts on which would be better? Thanks
Luke
#12 Cam-
Grind Number Part Number
MIT-246-10 431-0012
Advertised Duration-Int/Exh Duration @ .050
Int/Exh Lobe Separation Gross Lift
246 / 246 204/204 110 364/364
#14 Cam-
MIT-246-2SR-8 431-0014
246/238 204/196 108 364/345
with that kind of compression i would go with the #12 because it has a little bit better lobe separation and a little more lift on the exhaust side.
