[RESOLVED] 2g turbo Tach signal wire under hood???
Turbotalon25
98
Aug 30, 2008
Peoria, Illinois
Ok here is my problem I have a 1995 Eagle talon TSI awd 5spd
I just got my MAF translator and need to find a tach signal wire under the hood to tap into.
I've read alot of the threads but none have helped me. I'm no good with wireing so if some one would have a pic that would really help me out. :confused: PLEASE help....
Thank you.
Look above your injectors. Your power transistor is a pretty big plug. You're looking for PIN 4. It will the the FIRST PIN on the passenger side.
Something I found out tho in my own experience, your Tach will probably stop working when you tap the MAFT in. The tach signal voltage is too low to power both the tach and the MAFT. That I know of, there's no fix for this.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
