Car Wont Start
Jacie
49
Oct 3, 2008
North Ridgeville, Ohio
It was running fine, not problems at all. It's getting cold out side so I started it after letting it sit for a week for 5 mints, then turned it off. When I want to go start it again a week later all it does is "Click" and won't start... Any idea? The battery is only a month old....
Even though the battery is new it can still get low... the age just determines it's ability to hold charge running it for only five minutes didn't give it time to charge itself after using it's charge to start the car... if jumping it doesnt work the battery could be defective.. also check to make sure the cells have enough distilled water if it's a maintenance type battery... oh and first check the battery cables to make sure they're tight.
Try jumping it from another car sounds like the battery is drained. Maybe you left something on or door open a bit
i have the exact same problem i tried charging and jumping it wont even turn over, just a click.. nothin from starter it will only start when push starting. crazy how it can run fine then next day have this mysterious problem
