Join
- 200
- Jul 1, 2008
Vatne,
Europe
Hi!
I am currently rebuilding a s16G TD05H turbo. In the process I am doing a portjob on it. But for the turbine exhaust inlet, a guy at work that do 3D programming and modeling is going to help me machine that part.
He also have a Flow program that he uses, but I want to get some more input from you guys with the 3D skillz and flow knowledge how to get the best design.
I want the internal wastegate hole to be efficient enough to prevent boostcreep, but the main flow to get the quickest spool and highest performance is to be as little interrupted by vortex(es?) as possible.
Also it would be nice with some input on exhaust pressure, temps and airflow. Let's say 8000rpm's to have a solid startingpoint.
Just want the better design!
Anyone?
I'll post some flowreports in a while, need to scan them!
John
Anyone?
John
Do I want to enlarge the diameter all the way in, to where the snail starts? If so I can use a drilling tool and mill it out in there. No drills in aluminium..
I have some time to wait, I need to get the engine back in first, and run it in a little..
