First log EVER! just ideling. Your thoughts?
mitsu_matt
214
Nov 7, 2005
Lyon Township, Michigan
Ok, here is my first log with dsm link. this is a fresh build and I am just trying to see if I need to adjust anyting before I take it out on its first drive.
Let me know if you see anything! thanks.
Since you haven't adjusted anything, the car is running like it would if you had a stock, unmolested ECU. So it won't be running rich.
Your profile shows you have an AEM wideband - make sure you wire that in to the ECU so that you can log it.
I'm not sure what's going on with your front o2 sensor at the end of the log, but it's not cycling anymore. Make sure you keep an eye on that or you will get a messed up A/F ratio.
Next time, let the car warm up before you log, especially once you start tuning.
