High Idle
BenHooker
76
Jun 30, 2008
Seminole, Florida
Ok, I just installed a throttle body spacer on my car today. I have an automatic, and when I turn the car on, the RPM's rise up to about 3k and sit there. When I put it in drive, the RPM's lower to about 1.25k but are still higher than normal. I can't figure out what could be the problem. Any ideas?
My car was doing that the other day. Thers a set screw on ## throttle body, sorta on the top twords the front of the car. Turn the car on an run the screw in until u reach the idle rpms u desire.
The throttle body cable? No, it's in the right spot. My friend and I both looked over it tonight. Forgot to mention though, when it is in drive there is a hiss, so there is probably a leak somewhere I just don't know where to find it or how to.
It wont be a boost leak since your wishlist states a turbo and the cars a NT. You may have a vacuum leak though. Theck the vacuum lines and make sure the tb is tightened down.
On the throttle body, or around there, there should be a hole (fairly deep) that has a screw in it. I will see if I can find a pic.
