Timing question
BayState300GT
67
Aug 22, 2008
Allston, Massachusetts
Ok so Im going to be putting a 6 bolt in my car soon/ rebuilding the motor. I was just wondering when i rebuild it and i do the timiing belt when i put the piston a TDC does it matter what stroke its on? I plan on making sure that the piston is at tdc before i put the head back on.
the motor doesn't know what stroke you are actually on there is nothing telling it what stroke it actually is so just make sure #1 cylinder is at TDC and you will be okay so long as all your timing marks are aligned! hope this help! :thumb:
ya thanks that does help alot i will just make sure all the tdc lines line up and hopefully i wont bend any valves!
just make sure the crank is at TDC and the lines on the cam gears will be at 3 o'clock on the exhaust cam and 9 on the intake. You should also remove the 14mm head bolt on the side of the block and slide a screw driver in to line up the balance shaft if u have them. make sure all the marks are lined up and rotate the motor CLOCKWISE, I think 6 times to get the marks to line back up.
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
