mitch26753
- 354
- Aug 8, 2007
ridgelely,
West Virginia
Well i never really got a answer to this. Which Ac bracket do i need for a 2g awd with a 6bolt swap? I thought that i had to use a six bolt ac bracket? Is that true or do i use a 7 bolt ac bracket? with the ac bracket should both holes on the axle bracket be used or will i only use one hole? I have been getting about 50/50 answers to this. Half of the people say use the 6 bolt, the other half say 7 bolt. Then you got people saying just use washers. But then one of the holes wouldn't line up. I need to know the correct answer to this question. Because i have to order the right bracket and i only want to do it once!
Also i have heard there is a spacer you could buy? Does anyone have any FIRST HAND EXPIERENCE with that? I know i have heard alot of people talk about it, but none that have actually done it. So i just need to be pointed in the right direction. Also as far as i know the drivers side axle(which is the one that has the bracket that bolts to the block) is a awd axle. I bought the axle used, so it could be from a 2g fwd, would that matter any? thanks guys
