pulling tranny, easiest way to disconnect axles.
boosted86
414
5
Sep 7, 2005
Weston, Florida
Ok, its clutch swap time but and im getting ready to pull the tyrany. this is my second time doing this, and i honestly don't think its that hard, other then disconnecting the axles. i hate this part. so basically im trying to figure out a way to do this a quicker way. usually ill remove the upper control arm, tie rod end, and lower control arm. its a pita. Ive heard somewhere that by just removing the lower control arm the axles will slide out of the tranny is this true? and is there a easier way?
I used the same method he did, once you get in the swing of things can have them out and back in, in no time.
I just noticed that link takes you to the main page. The one I was trying to get you to was the drivetrain>1g clutch install link.
yea, thanks guys, but i think that the 1g's and 2g's have different suspension setups. wish i had a 1g, probably a lot easier....
nope just do everything like you had it and they have different suspension setups but you can still pull it out with the spindles on
