Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 09-22-2008, 01:06 PM   #1 (permalink)
New Member/Lurker
mike hobbs's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: mike hobbs is an unknown
Question car shut of!!
wats up fellow dsmers i need some serious help. sat night i was at the local spot and we all left to watch some hondas do some highway pulls. the did some runs and i was in the middle but i didnt run anybody cause of a little clutch slippage, now they took off and my car turned off on the highway. i pulled over and tried to push start it but it didnt work. when i tried to start it everything lit up the lights was bright and everything but it wouldnt crank. now the belts turned but it wouldnt crank. my girls car did the same thing and a mechanic did a test and the car fired up, then cut off. he told her it was her fuel pump, could that be what it is? please help cause i miss driving my baby
____________________________
i luv my DSM
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 09-22-2008, 01:22 PM   #2 (permalink)
New Member/Lurker
Region: SoCal
Reputation: Nito15 is an unknown
To check if its your pump, you can try giving the gas tank a few hits or kicks. That will hopefully get the fuel pump free and flowing again if it is failing. Crank it over after giving it a few hits and it should start. If that is it, it still will need to be replaced.
Offline
Old 09-22-2008, 01:44 PM   #3 (permalink)
New Member/Lurker
mike hobbs's Avatar
Region: Midwest
im about to try that
i luv my DSM
Offline
Old 09-22-2008, 01:58 PM   #4 (permalink)
Proven Member
ShawnsGarage's Avatar
Region: Southeast
Classifieds Rating: (1)
Reputation: ShawnsGarage is an unknown
Crank the car over and then when you stop listed to hear if the fuel pump is making a whining noise. If it is then its still pumping. Also try spraying some injector cleaner into the intake and try to start it. If that works and then it cuts off you are not getting fuel.
Offline
Old 09-22-2008, 02:55 PM   #5 (permalink)
Proven Member
AlaskanDsm's Avatar
Region: Pacific Northwest
Reputation: AlaskanDsm is more helpful than not
Check for fuel and spark.
when my fuel pump went out, my dad's buddy came and brought a little hammer and while I was trying to start the car her got under the car and hit the tank twice pretty hefty and the car started.
The other thing to check is of your car has any spark. check the plugs for sprk using an extra plug. just pull off the wire and plug in a new plug and turn the car over and see if there is spark. try all 4. if none have spark, time to start working backwards from there.
-Matt
Offline
[posts] [blogs] Reply With Quote
Old 09-24-2008, 06:41 PM   #6 (permalink)
New Member/Lurker
mike hobbs's Avatar
Region: Midwest
ok ill try this tomorrow thanks and ill keep postin.
i luv my DSM
Offline
Old 09-24-2008, 07:20 PM   #7 (permalink)
Proven Member
98DropTop's Avatar
Region: Central Canada
Reputation: 98DropTop is an unknown
maybe its your CPS (crank positioning sensor)....
My car pretty much did the exact same thing... I was driving to my buddies house to pick him up, as I was turning into his long driveway, I threw it into neutral so I would just roll up to him... I had my music at a moderate level, but not loud, So I didnt notice anything strange... As I came to a hault, I turned my music off and my car was already off, like as if it was stalled. I tried starting it... nothing... wouldnt turn over at all, the engine would crank like a champ as if it was going to start but nothing after... All my accesories would work fine, etc. I was baffled until we ran the ODB and saw the code...
-if not that, maybe the CAS (cam angle sensor)....
Hopefully it is what someone mentioned earlier or this.... good luck
edit:
p.s your missing a 'f' in your title... Might help more if title is spelt correctly, even though its pretty self explanatory.... lol... :P
Offline
Old 09-24-2008, 07:24 PM   #8 (permalink)
Proven Member
assault187's Avatar
Region: Tri State
Reputation: assault187 is more helpful than not
Wait....You said the car didnt crank...Then you said that the belts moved but it didnt crank??
Assuming it DOES crank since the belts moves and it just doesnt start, check fuel and spark, also check the CAS plug. If the CAS plug pops off or the CAS died, you will lack fuel to the cylinders because the injectors wont fire and the car will not start. But 1st check for fuel pressure and spark
Offline
Old 09-28-2008, 03:16 PM   #9 (permalink)
Proven Member
Region: Tri State
Reputation: Semprini is an unknown
This happened to me yesterday. I have a rewired pump, and some how the fuse popped
Offline
Old 09-28-2008, 03:23 PM   #10 (permalink)
Proven Member
Region: Midwest
Reputation: interex is an unknown
EXACTLY what I was thinking when I read it.
Online
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
car just shut off bkdsm89 Newbie Forum 5 09-29-2008 05:20 PM
Crank but no start, Replaced multiiple parts, shut car off then car spark, wtf !!!! ShadeTreeDSM Problem Diagnosis 15 07-08-2008 01:34 PM
Car won't shut off 95gsx4g63 Problem Diagnosis 1 11-24-2007 11:51 PM
Car won't shut off... res7bequ Newbie Forum 19 09-08-2007 12:27 PM
Car won't shut off 92whitetsi Problem Diagnosis 16 12-15-2002 02:31 PM
Page generated in 0.19060493 seconds (78.00% PHP - 22.00% MySQL) with 10 queries
