Trelisong
- 88
- 7
- Sep 6, 2006
Denver,
Colorado
I just about finished my 6bolt swap on my 2g and I was going to start it up once before I put in dsmlink, I figured better to hear it run so I dont have to guess weather or not the problem is link or the car. Then after i run it once Ill hook up dsmlink and set the timing.
I found one of the lines to the Turbocharger Waste Gate Solenoid Loose.
I am pretty sure it goes to the intake box air line, at this broken nipple, am i correct? if so what do you think I should do? Was wondering if maybe I could just plug this one with a screw and feed it vacuum someplace else, or does the vacuum source need to be from that specific spot.
