radiator fan fuse
optional187
55
Nov 15, 2003
Newberry, Florida
minor problem which leads to an ongoing overheating problem. long story short i pulled the radiator a few weeks ago and ever since i've been blowing radiator fan fuse's like its nobodies business. the drivers side fan works fine, but the pass. side doesnt work at all because of this. i can turn the car on to the "on" position and everythings still fine, however when i crank the car the fuse blows immediately.
i figured maybe it was my turbo timer shorting out and causing problems, so i used a harness to connect it...still causes problems (and on a side note the timer displayed just a "3" or three backwards "C"'s.) so i took it out completely. still blows fuses like crazy.
need a little bit of help here cause i dont know what else to try and its getting expensive with the fuses being $3.50 a piece.
