W4A331FM6 1G AWD atuo trans??
91AWD4G63
Jul 14, 2008
Paulden, Arizona
Ok so i have a 91 gsx with an atuo trans..I bought it with the transmission broken and I purchased a new transmission from ASAP motors they sent me one with the code W4A331FM6 and my old trnsmission i took out was coded W4A33K1UP6 all I found on this is that it might be from a '94 gsx but it has two extra tranny mounts so basically asking is will this transmission work with my car?
That is a 7 bolt AWD Transmission. And not all (7 bolt) transmissions are the same. They have a few different models with different features.
Your car is a 6 bolt. It is not a "direct swap".
They started making the 7 bolt in 92 1/2 so a lot of places think that the 89-94 will be the same but they arent all.
it should since its the w4 code. But I am no automatic dsm wiseman
ahhh ok trust interex that sounds right;)
I did see in the other article that it requires the flat flexplate which is already on my engine. the only real difference that i saw that gave it away is that there are two extra mounts on this transmission that are not on my car... at all.... and also like two of the wires are different color-coded. other than that they look pretty much the same..... Also, how many bolts actually connect this thing to the block? I only found 2 :cry:
please tell me one of those bottom bolts arent on the front of the block (a piece of the block is missing there) :cry::cry::cry:
LOL, dude... You gotta be kidding me... The bell housing of the transmission will show you where the bolts go.
yeah figured as much...... when i took it off it didnt have a bottom bolt installed so wasnt too sure if it went there or what and i havent lined it up yet but yeah i need a new block.... its broken right there so its off to friends house to pick up his six bolt.... also I can just run it with the one tranny mount right? like the normal six bolt first gen tranny or what do I have to do cause you said it wasnt a "direct swap" ...... hondas were so much easier LOL
I'm not too sure about the mount situation as I don't mess with 1G cars. Might just wait and see if anyone replies.
