2g Help Please!!!!!!
venumnos
96
Jul 15, 2005
north miami beach, Florida
Ok I Have A Huge Problem And Im Running Out Of Ideas. I Have A 2 G With A 20g And All Fuel Mangmnt. Everything Was Running Fine In The Car I Turned The Car Off For About 10 Min. I Turned The Car On I Was Flipping Threw The Monitor Screens On The Safc Ii Then I Went To Drive Off And The Car Compleatly Bogged Out. The Car Was Almost Not Driveable... I Had To Drive It About 10 Miles Home Barely Made It Home. The Car Idels Perfect!!! I Give It Gas It Boggs Compleatly!!!there Is One Throttle Point Where It Does Not Do It Any More Or Less It Bogs???? This Has Me Blown I Have No Idea What It Is??? It Gets Gas And Alot Its Realy Rich!! I Have A Friend With The Same Car Swicthed Maf. Not It. Map Sensor Not It. Tested Injectors Not It. ... Could My Safc Gone Bad??? But Still Work As In Everything Works In It But The Car Not Reading??? Some One Please Help I Need My Car For Work.!!!!!!!! Wisemen????
Did you just hook up the afc or has it been hooked up. Check teh wiring and make sure that the maf wires havent came unhooked. Is the afc still reading karmen on the screen? IF not its not recieving a signal from the maf
Yea It Is Reading Karmen And I Had It Hooked Up For About 3 Years Now!!! And The Plug Is On Good I Rechecked All The Wiring.....
Did u switch any settings? Like 6 cylinder instead of 4? Or did you reconnect the maf? If you have everything correct... i would just pull the battery plug for about 10-15 mins to reset the ecu. Hopefully that fixes it. Otherwise do a diagnostic check? You do have a logger.... correct?
Yes I Have A Logger And I Check Everything Its Showing. Its Says Maf /vaf But Like I Said I Changed It But Nothing Happend. Could It Be Clogged Fule Filt? And And Another Thing When This Happened My Boost Gauge On The Cluster Dropped All The Way Down And Wont Move From There At All No Even When Im On Boost. I Turn The Car Off And It Goes Back To The Middle.....
The Sensor For The Stock Boost Gauge Goes To The Maf? Ok Ill Check It Out But Like I Said I Swaped It With My Friends And Same Thing... Connection Is Good Dats For Sure Would you Happen To Know What Wire It Would Be?? Thank For The Help Guys I Appreciate It.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
