dacowgod
Supporting Vendor
- 451
- 280
- Feb 3, 2006
Morgantown,
West Virginia
So ya... I just rebuilt my engine...for the 2nd time was with Ross pistons, eagle rods and the 6 bolt crank ..walked... yay.. so round 2 I went all out got some 9.0:1 wisecos eagle rods and bc 280 cams and meth injection...got everything tuned awesome.. 28 lbs of boost on a 60-1 w/ 21 degrees timing advance and 12:0:1 a/f.. it was rockin... and 300 miles later timing belt snaps... after investgation i found a locked up brand new top line oil pump to be the problem.... Oh well i expect the worst, valves through pistons and spun rod bearings...so i tear down... To my surprise.. NO BENT VALVES... woohoo i couldnt get so lucky ... i get to the bottom end and the first thing i notice is #1 rod cap is PURPLE from heat..... not good... so i pop off the caps and sure enough bearing is starting to show signs of failure (flaking the top silver layer) ... and the bearings do not fit in the rod quite right...
SOOOO anyways I suppose I am to a question.... Is there a way to test the rod to find out if it is safe for re-use or should i do the obvious safe thing and replace the rod all together... REALLY want to be back together by next wednesday (Race day) so obviously if i have to wait on 1 stupid eagle rod I'm gonna be pretty upset ...
I buy all my jazz from slowboy so maybe they can help me out of this one quick, we will see oh well thanks for reading hope theres a safe way to test that rod, but my hopes dont lead to far...
