Installed Trans Lab shift kit. No 2nd gear now.
pcweber
Aug 16, 2008
Eagle, Nebraska
It shifts fine, O/D works perfect, etc. (2nd worked OK before installing) I get a 1st direct to 3rd upshift, even when manually shifting from L to 2nd. If I turn off the O/D and it is 3rd and pull the shifter down into 2nd it stays in 3rd. Any idea what I may have done? I assume I need to pull the valve body back off, just wondering if there is some common issue that causes this I should look for?
