Which Bullseye Turbo Is This ?
2ndgendsm-md
Aug 15, 2008
Westminster, Maryland
I recently purchased a bunch of dsm turbo parts and im selling what I don't need, however, I am not sure which turbocharger I have here. I was told it was a Bullseye turbo capable of 500 whp ? It is pretty large, but it has almost no casting marks to identify it... Id feel like an idiot selling a turbo I cannot identify, any help would be appreciated, thanx
Also, does anyone recognize this manifold ? It looks pretty sweet, and has a large wastegate flange, it is also not labeled anywhere...
please send me a message if you can help out, its pretty frustrating trying to figure out this stuff on a weekend when everyone is closed
ok, so heres what I measured:
compressor inlet - 2.75"
compressor outlet - 2"
I didn't take off the compressor cover (I have no tools at home) but I measured what part of the compressor turbine wheel was showing if that helps anything - 2 1/4"
also the exhaust wheel - 2 5/8"
note: these measurements arent perfect - also I measured the outer diameter of the inlet and outlet
any ideas ?
The size of the compressor housing leads me to believe its most likely a 57 trim, but it is slightly possible its a 60-1 with the "small" compressor cover.
Bullseye T04B 60-1, P-Trim turbine. 3" compressor inlet, 2" compressor outlet. Your turbine housing has a Garrett T3 inlet flange with a Garrett 4-bolt or 5-bolt outlet....it's drilled so either outlet flange will fit.
I used to have the same turbo in a DSM Bolt-On; ended up letting it go for the "right price" to a DSMer in need:
