[RESOLVED] NEVER use a longer clutch rod
if you need to use one you have another problem elsewhere. whether it be a bad pivot ball, clutch fork or bad hydraulics
"If you are having problems with a clutch adjustment, don't be tempted to try to lengthen the clutch slave cylinder rod. It may work for a few symptoms (worn pedal assembly mostly) but it is not the right way to fix things. In order to take up additional free play, it puts constant pressure on the release bearing. "
Bottom of the page:
RRE's Clutch And Flywheel Tech Info
