clean96GST
- 462
- Jul 14, 2008
Arlington,
Washington
Ok so my 96 GS-T either idles really high at about 1500 or it will just be on the line of dead or dead. Does anyone know how i can fix it?
Wow that is a sweet site! thanks a ton. So if i take off that screw it should be obvious if that is the problem and i need a new o ring right?Do a boost leak test and check your throttle body area. You might need a new o-ring in you BISS Screw. I had that same problem.
Here's were the BISS Screw can be located.
http://members.shaw.ca/dsm.1000q/Engineprimer/2G/throttlebody.htm
It's circled in purple.
