clipse4u2c
- 47
- Feb 10, 2008
Hebron,
Kentucky
Well, I'm getting ready to start my 7 bolt rebuild. I'm thinking of possible making a vfac when i'm done on the assembly or anything else I think a vfac might be helpful. I just sent the block to the machine shop and had it tanked (even though I don't think it looks to great), freeze plugs, honed (didn't need bored thank goodness), micropolished crank and cleaned/inspected the rods and pistons. I'm planing on reuseing the 2g rods and pistons since it doesn't need bored. My parts list is as follows tell me what you think
OEM BSEK (MD040597,MD103722,MD092785, MD098626, MD128107) bought individually (its cheeper that way for some reason!)
Topline or OEM front case
ACL Race Rod/Main bearings from MAP
Leaving the oil squirters alone
Topline Waterpump from ext psi
OEM timing belt either from JNZ or individualy from dealer whichever is cheaper. does anybody have the tensioner part #
ARP Head Studs (207-4203)
Cometic MLS Head Gasket (arp+gasket kit from ext psi)
Punishment Racing radiator and fans
Megan 2.5-3" downpipe from JNZ
Removing all unneeded sensors ( from vfac 13.Fuel pressure sensor valve, 14. EGR, 18. Hood latch, 28. Theft Alarm, 30. Boost control, 35. Evap, 43. L fog, 44. R fog, 52. Fuel pump.
Topline, NPR, or OEM Rings (your thoughts?)
New Upper and both lower control arms for both sides
New tie rod ends
New rotors (I'll probalby go autozone or maybe brembos from tirerack)
160 T-stat from JNZ
Energy suspension motor mount inserts
Rebuild Non turbo 1g throttle body
Remove cruise
OEM Fuel Filter
I will abviously need some gaskets for the rebuild but haven't made a list yet
I will also be getting alot of parts powdercoated so it will be nice and pretty
What do you guys think. I'll hopefully be posting pics along the way but my camera broke so i'll have to get it fixed first.
New tie rod ends
160 T-stat from JNZ
Remove cruise
OEM Fuel Filter
