cjridert1
- 403
- 6
- Jul 4, 2007
Akron,
Ohio
Pull in 3rd today (ran fine so far - just got valvetrain/head on). The car FELL on its face ~5.5k then could barely drive nearest parking lot . Got the car home - pulled the wires, checked the plugs, checked compression. Plugs were white tipped on wideband had read (18+):1 lean. Car runs no diff with 1&4 injectors off, but stalls with 2 or 3 turned off.
Checked spark in the parking lot - wires for 1 & 4 gave no spark. Car got home, then all had spark. Started up and idled fine. So I took it out again and stayed close to home. Same deal - car gave up and I limped in around the block. Again, 1 & 4 have no spark.
Coil pack? What do you guys think? I had problems with the thermostat wires shorting a bit I think; they were causing the ISC motor to flicker around. Related? Thanks much in advance for the help guys!!
