knochgoon24
DSM Wiseman
- 6,135
- 97
- Jan 29, 2008
Troy,
Michigan
So I know my front wheel bearing needs replaced. I also have to replace the outer tire rod. The tie rod ends aren't expensive ($28 for a set from advanced auto), but the wheel bearing and hub is ($140).
So, I searched Ebay and found someone selling an ASIAN brand wheel bearing and hub.
I know that AISAN made some of the OE parts for DSMs, so would this be an ok replacement part? It's only $74 with shipping so it would save me quite a bit.
Here's the link eBay Motors: 95-05 Mitsubishi Eclipse Galant Frt Hub Wheel Bearing (item 190220977364 end time May-18-08 11:57:59 PDT)
or
(Both parts went bad because I hit black ice, then a hillside this winter. I finally jacked my car up and checked the wheel because I heard the tell-tale grinding noise. The amount of play is insane.
