Electrical problem!!!
icerob
98
Jan 4, 2006
Queens, New York
its 97gst the car starts up fine but the problem is, the radio stop working on, windows stop working, sometimes when I turn my car off the headlights will stay on when the switch is off, then sometimes my horn will go off for about 2mins straight non stop.... so some input we will be appreciated here.. thanks
alternator how will a bad alternator do that? Was there an after market alarm installed on it? Check the wiring under your steering wheel. The ignition gives power to many things in the car. Ignition will power your radio and windows. Also you have 2 other problems within the steering wheel area, light/turn signal switch and horn. I would take a look at the wires under your steering wheel for sure.
yea I think your right I think it is my aftermarket alarm because its all F up too, I will disconnect it today. Ill let you guys know what happen
those were the exact same things that happen to me when the alternator FUSE would pop.
windows not rolling, radio not working. and headlights would stay ok.
yep. and it was due to my cheap alternators along with the FUSE.
and i do have an alarm also, but didn't have to do anything with it.
hahahahahaha, the good old horn staying on too!!!!!!!!!!!!
LOL. i was racing one time, and i poped the alternator fuse, and that fkin horn stayed on.
had to pull over and change the fuse, Good thing i always carry one in the glovebox.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
