cyclonekid77
- 383
- 2
- May 18, 2007
Bellevue,
Ohio
im building my six bolt and i was wondering what crank and rod bearings you guys recomend. i was thinking either oem or acl. im goin to be using wiseco 9.0:1 pistons with eagle rods if that helps any. thanks
).. if it is tapered or not the right spec, then you need to machine, or change the bearing accordingly... its rreeeaaalllyyy easy.. just get very familiar with the process by reading the engine rebuild section of your manual a few times.. again.. very simple process, but is must be done correctly, otherwise you will be rebuilding it again very quickly..
unless you are trying to build a motor with 600+ potential I have 3 friends who run stock bearings and one just dyno tuned at 436 WHP. He has had the car and this setup for 3-4 years now> He drives it 2-3 days per week.
