New clutch New problem No power HELP
DearDoger
123
Jan 26, 2008
Battle Ground, Washington
Alright I replaced my clutch pain in the ass. Whatever i finish it go to start the car Nothing no electrical power any except to my starter.I checked all the grounds even made new ones. Battery has full power. all the fuses are fine. so i checked everything over and over. I jumped power to the fuse box and everything turned on but the ecu rapidly clicked. Any advice could help this is my daily driver so if a few guys could try and help me through this then you are awesome.
Honestly it sounds like you have a problem with the main feed wire going to the starter. When you say you have power to the starter do you mean the starter spins over or just that you checked the voltage at the starter terminal?. Also recheck the main fuses at the battery. Dont visually look at them. You need to ohm them with a meter. They can look fine and still be bad. Check this and post back and I will continue to try and help. I am sure others will offer advice as well. Travis
The test light shows the starter has power I am going to borrow a multimeter today see if I cant come up with anything.
