Aeromotive Pro-series boost reference fpr?
1997hciv
94
Mar 6, 2005
Whiteford, Maryland
I have searched and could only find one thread on this fpr. I wanted to know if anyone is running this or has any experiences with it. I know it is the overkill -10an line but I can get this from a friend for next to nothing. Would it be worth it to run this over the normal Aeromotive fpr. Any imput would be great. Thanks
It looks like it just has more ports than other afpr's. This isn't a problem, you can just block the ports off you don't need. It should work fine for you. Also, you don't have to use -10 lines. You can use reducer fittings in the afpr to use whatever size line you want.
