TB2K
- 65
- Feb 20, 2008
Lake Station,
Indiana
I got a compression test today with a result of (starting with the air filter side of the engine) 150, 135, 125, 150 and it held. We could actually see water coming out of the water pump. So how likely is it that it is just my water pump? also is it very hard to do the balance shaft removal while I have the water pump/timing components off or does it need to come apart more?
but he is now saying it may be a sensor... the only thing that changed was the waterpump and timing belt and that the car was at a decent angle for about 5 hours. I can't see how a pump can make a difference in idle, the tilt thing can't still be effecting it after 3 days so I thouht it would have to be the timing. What do all you so much wiser than I have to say?
