gotboostsc
- 45
- Jan 21, 2008
Weatherly,
Pennsylvania
I have a 1992 Talon TSi and it seems to have 2 drain plugs for the gas tank. One more towards the driver side of the tank as many do have but I also have a smaller bolt basically in the center of the tank. Of course this one is leaking and i have tried a series of crush washers/ rubber gaskets for this bolt but it continues to leak just the slightest bit. The bolt seems to be threaded into some kind of plastic which incorporated into the tank. First of all my question is does everyone else have this center drain plug also? I have searched and everyone only brings up the larger plug more on the driver side of the tank. My second question is does anyone have any ideas to stop the leaking? I thought about using some kind of plate and sodering it to the tank to just basically block the hole completely or I thought about using some kind of hardening epoxy to spread around the area it threads into (the plastic piece that seems loose) and see if that solves it.. I really dont like leaking gas near my hot exhaust so let me know if any of you guys ran into this before or what you suggest to solve it. Thanks guys.
. And yes, the gas tank from a N/T will work in a turbo car. To my knowledge there is no difference. Although, you shouldn't have to swap the entire tank, just that rubber piece.
