AlphaVision
- 297
- 1
- Jan 28, 2007
Sofia,
Europe
Hi guys.
First - a little info on my Eclipse. It is an European model. 1999 GS with 7 bolt 4g63 non-turbo. Surprise!!
Now I am doing a 6-bolt swap. First of all my wiring is different from 2g turbo wiring so I will have to change the wiring with such from a turbo car. Second - the 6-bolt is complete engine...everything is there - sensors, pipes, injectors etc. The wiring was cut at the place where it was going trough the firewall so no connectors are present...
Initially I wanted to use a 2g ECU and do the Magnus swap. To accomplish that I had to buy the engine wiring, change all the sensors on the 6-bolt and buy a 2g turbo ECU.
Then a friend of mine told me that it would be better to use the 1g ecu, because the motor is 1g, and the fuel maps are programmed for this engine and all the sensors are there connected. I want to go that way but there is some stuff i need help with.
I've made a comparison between 1g ecu and 2g ecu. The matching pins are marked with a star. But what about the others. I don't understend what most of them mean and how can i control them without the ecu.
I need your oppinion - how to fix the stuff that won't be working with the 1g ECU.
thank you all
thank you all
