Black94DSM
- 815
- 27
- Jan 17, 2006
Madison Heights,
Michigan
Ok so I searched for a bit and still dont know whats going on here.
I have a 92 GS-T as a Daily Driver, and this car knocks like crazy when I hit 2,500 rpm. It does this always.
I could swear that I put the balance shaft belt on correctly as far as lining everything up, but is it possible if it is off, will it make the engine knock at a consistant rpm? It goes away around 3,000 rpm...or a little later.
The spark plugs are new, the spark plug wires look good. There are some slight boost leaks ( but ive never had this type of problem with boost leaks). Will a hacked MAS do this ? The previous owner put on a hacked 1g mas.
I need opinions on this please.
Thanks for the help.
, but im sure thats not the problem. Ive had motors with far more lifter tick than this one and not pull any timing.
