Problem in shifting
SubZero
Dec 18, 2007
Dubai, Asia
I have problem in my DSM ( Fwd )with the clutch. There is voice coming from the GearBox and when I pump the clutch and try to shifting it dosent shift by easy but the voice be silent. I have to push it hard to shift and sometimes it dosent work. I get the engine out and check the clutch( new OEM clutch disk ), its OK. The bearing was dirty and I clean it. What do you think ?. Is the problem from the bearing or something else ?. Is there way I have to fit the pressure plate because its fit in 3 ways but in my honda there us only one way.
I checked the fluid level is ok and no bleed.
should bleed the clutch? does the pedal ever jsut go straight to the floor? Do you know how to bleed it to make sure there is no air in the line? do you understand now
Dude... relax, he's from Asia... there's obviously a language barrier. I'm guessing that "bleed the clutch" doesn't translate exactly.
To the OP'r... what he's saying is make sure that your clutch line doesn't have any air bubbles in it and that you should try opening your slave cylinder "bleed" valve and pumping the clutch pedal. Obviously, be sure to hold the clutch down all the way to the floor before tightening the bleeder valve. That way you'll be sure that you don't accidently get more air in your clutch line.
I'm not confirming that will fix your problem, just trying to explain Mitch's post. Does that make sense? I'm guessing from your OP that you havent' 'bled' your brakes as of yet.
  • Wanted HAFE/BEP external gate manifold
    In search of/want to buy Old school exhaust manifold with external wastegate flange. Preferably...
    • Jacob5se
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
