1gWill
- 1
- Aug 30, 2005
pensacola,
Florida
edit: Thanks for your help everybody! I'll keep the pictures I posted below hosted so they can hopefully help other people.
First off, I have searched and I can't find anything specific to my questions. My car is a 95 TSi FWD with a 91' 6 bolt.
My harmonic balancer went out yesterday as I was driving so I gimped home having to pull over every few minutes to make sure it didn't over heat. Anyway, my questions are:
What's the best way to get the pulley off? I already have the 4 bolts removed but not the center one. Will a torque wrench and cheater bar do? My friend said I should be careful not to spin the motor backwards? I didn't quite understand that. If someone could elaborate or help I would appreciate it.
I already have a new crank pulley. I just went and picked one up from Advanced with a lifetime warranty. It looks to be in good shape, I inspected it, etc... but there is no rubber ring around this one like the stock one had. The reason I'm replacing is because the stock rubber ring around the pulley has a chunk missing out of it.
Should there have been a rubber ring around the one I got from Advanced or what?
