Ragincajun
- 34
- Dec 14, 2007
Waxahachie,
Texas
Did a search and found one thread to help a little. I cleaned my motor sunday. Well of course you all know the problems I had being a newbie. So I dried the spark plug area, and the car runs much better. Now it only bucks and sputters at boost over 8. (everything is stock 90 Laser 2.0). I changed the plugs, and noticed that the one of the boots on the plug wire was cracked and missing a chunk of plastic. Could this be what is causing the problem I am having at boost. I am hoping it is not the Crank angle sensor or something like that.
Also I have another question (without searching).
When I shift from first to second, I grind. This happens at normal driving. If I granny shift. (let the Idle down all the way) and shift real slow it doesn't do it.
Any help would be greatly appreciated.
