Logger question's
2gtalonman
226
2
Feb 4, 2005
Green bay, Wisconsin
I got my car running and I'm having a cooling issue, my gauge says its way hot but my logger is telling me its at 96 degrees Cel. I have no idea what that is in Farenhiet, is there a way to change to farienhiet? I know its suppose to run between 180-200 F
also it looks like my radiator is smoking and the radiator cap a bit also.
theres very little pressure in the uppser hose :( any ideas?
I'm also running a g-vr4 sensor for my coolant sensor (the one with one prong only) its for the gauge... does this matter?
96 Celsius is about 204 degrees Farenheit. I'm betting the logger is correct and the gauge is not. If there's no pressure in the upper hose, I would verify that the thermostat is functioning.
Got the car running alot better, no leaks ect... the upper pipe has more pressure in it thanks for your time. Now I have to figure out why the OEM gauge is off.
