oil leak.
microgalant
111
Aug 27, 2006
Aruba, South America
Well i saw an oil leak, near the timmingbelt cover.
Took it off, and i saw this.
What would be the problem?
Front seal?? or bad oilpump cover?
YouTube - 7g
There really isn't enough there to tell for sure what it is, but you might check your oilpan gasket for leaks and possibly a leak higher up that has drained down. Does it leak more with the engine on?
I washed the whole engine with purple blaster,dry it, and when i start the car you can see clearly the oil coming from behind the timing trigger plate.
Sounds like the front main seal is leaking on you given that information. :(
