problem with turbo
joevodka69
Mar 12, 2006
belmar , New Jersey
i'm having this problem with my turbo system. i am getting blue smoke coming out my tail pipe, so i suspected it was the seal. i replaced it with a new turbo and same thing. so now i decided to take off the turbo to see if there was somke from the eninge but found none. then i put the turbo back on and removed the oil feed line but same problem (smoke from the tail pipe) then i removed the oil return line and no more smoke. ? i'm lost and any info appreicated
If you are gunking up in your return line, you could be gunking up other places, too, though. Now might be a good time to flush out your oil system, too.
