car ignition problem
16g-2ndgen
243
Nov 2, 2007
FLW, Missouri
i have recently changed out my head gasket and all of the front main seals becouse of major oil leak. now after all of that is fixed my car decides that it dose not want to work by not sparking, at first i automatically jumped to the conclusion that the powertransistor and coilpack were bad, soo went and bought a brand spankin new one for 90 bucks and still same results, then i checked the cam angle sensor with a volt/ohm meter to see if it was giving out power and it was. i figure that that dose not mean that it is opertating properly, i want to know if the 2g 7 bolt cas will work with the 1g 6 bolt. and what would be your input. im hoping that it is something real stupid, and most likly is.
thank you for your time,
jordan
