Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 10-19-2007, 06:14 PM   #1 (permalink)
New Member
Region: Midwest
Classifieds Rating: (0)
Reputation: 90laserblackrs is an unknown
Wheel hopping
Hi how in the m=world do i stop my car from wheel hopping its a 90 laser FWD. THANKS ALOT!!!
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 10-19-2007, 06:22 PM   #2 (permalink)
Proven Member
Region: NorCal
Reputation: jlado13 is an unknown
Urethane motor mounts should help for sure. Increased vibration, but should help alleviate wheel hop. Along with some suspension adjustments.
Offline
Old 10-19-2007, 06:23 PM   #3 (permalink)
Proven Member
absolute_DSM's Avatar
Region: Rocky Mountain
Classifieds Rating: (5)
Reputation: absolute_DSM is pretty helpful and trustworthy
AWD? Change your driving habit?
OR
Prothane motor mounts front and rear.
____________________________
Eric
Offline
Old 10-19-2007, 06:59 PM   #4 (permalink)
Proven Member
dsmulla's Avatar
Region: Eastern Canada
Reputation: dsmulla is an unknown
Well there have been a lot threads about FWD and wheel hop try using the search button to your advantage. Now another you could reduce wheel hop is lowering the car from the front more aggressively. You don't want to go to low so you hit curbs in you daily driving. That way the cars weight will shift to the front putting more weight on the front wheels.
Osman
Offline
Old 10-19-2007, 07:13 PM   #5 (permalink)
Proven Member
laserspeeddemon's Avatar
Region: Mid Atlantic
Classifieds Rating: (4)
Reputation: laserspeeddemon is extremely helpful and trustworthylaserspeeddemon is extremely helpful and trustworthylaserspeeddemon is extremely helpful and trustworthy
Motor Mount Inserts.
Front Control Arm Bushings.
Front Sub-frame Bushings.
Front Sway Bar Bushings.
And in you're combo of struts with a hard setting and a set of lower springs with a hard spring rate and you're good to go.
Oh and an LSD would help too.
Sean B.
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Old 10-19-2007, 07:43 PM   #6 (permalink)
Proven Member
cruisintalonawd's Avatar
Classifieds Rating: (2)
Reputation: cruisintalonawd is an unknown
Why do some cars have wheel hope and others don't?Tires? i have the same year and model of car
Offline
Old 10-19-2007, 07:48 PM   #7 (permalink)
Proven Member
Region: NorCal
Quote:
Just like fuel and engine tuning... Every car is different. What works on one car may not work on another. Even the way you drive can contribute to wheel hop. I'm sure having a good set of tires would probably exaggerate wheel hop too, due to them attempting to "hook up" better. Worn tires would just spin out of control.
A lancer I used to have would just spin tires like crazy. Once I actually got some good tires on there, it hopped a bit.
Offline
Old 10-19-2007, 10:52 PM   #8 (permalink)
Proven Member
Zmann42087's Avatar
Region: Midwest
Reputation: Zmann42087 is more helpful than not
Energy Suspension motor mount inserts cured my wheel hop issues.
-Andrew
Offline
Old 10-19-2007, 10:53 PM   #9 (permalink)
Proven Member
Region: Midwest
Reputation: jwcardy is an unknown
now, im new to dsm's, but i cured the wheel hop issue with my srt4 by simplying adding solid motor mounts...
-wes
Offline
[posts] [blogs] Reply With Quote
Old 10-20-2007, 04:42 PM   #10 (permalink)
New Member
Region: Midwest
Thanks Alot!!!
Offline
Old 10-28-2007, 11:29 AM   #11 (permalink)
Proven Member
Reputation: poooch isn't as helpful as most
i can vouche for the lsd theory it works wonders using performance lsd's on the car
Offline
Old 10-29-2007, 11:51 AM   #12 (permalink)
Proven Member
Region: Midwest
Reputation: JohnnyT is an unknown
Learn to launch better and wheel hop will be minimal. Do everything everyone else said too.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.17779398 seconds (79.78% PHP - 20.22% MySQL) with 9 queries
