Datalogging question.
91talon27
214
Jun 13, 2005
Middletown, Ohio
I just made a 3rd gear pull while data logging and I am only seeing 69% throttle with my foot on the floor. Anyone have any ideas as to how to fix this? I tried to adjust the throttle cable but that didn't help at all.
First off.....
1. Have someone sit in the car and hold the throttle to the floor. Look in the engine bay and see if you can rotate the throttle butterfly any more. If you cant, the you may have a faulty tps sensor. If the tps sensor is bad, it could be showing the ecu that your going 69% throttle but your actually at 100%, you could lean out the car badly. Im not 100% sure if thats how it works exactly, but that is just my thought.
2. Are you running cruise control?
If your TB is opening up all the way. The TPS needs to be adjusted. Loosen the TPS screws holding it in place and rotate it until you get the proper reading from your data logger.
What does your TPS read at idle?
Mine is usually around 12% or so @ idle. Leave the car off (ign. on) and just twist the throttle plate deal attached to the cable all the way open - it should end up around high 90's% (100% ideally) . You can check your TPS voltage/ohms (forget the #'s - sorry) if you think it might be bad. Here is some more info: http://90gsx.com/eclipse/tps/tps.jpg
Good luck!
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
