Clutch issues
boosted95clipse
32
Apr 25, 2007
Eugene, Oregon
I read through alot of moderatly similar issues but not quite what i have going on. I have a 95 gst. So when i was breaking in the clutch it would engage just off the floor and it felt all fine and dandy and then a few hundred miles in it started engaging a little higher off the floor and then higher and sometimes it will engage low agian. It still grabs hard and doesnt slip so I am not sure what the problem would be. Does it just need to be adjusted or what could it be? Thanx in advance
bleed your clutch and make sure you get all air out of the lines. Air bubbles in the clutch line will give you an unpredictable grab point. If this does'nt help, Look into checking the master and slave clutch cylinders.
